Wishes
Wish item: ability to join meshes and retain node levels
I'm working on a large site (200+ houses) in teamwork and unless we split the mesh up (resulting in unwanted lines in 2D where the meshes join, and having to marry up levels) only 1 person can work on the mesh.
If ArchiCAD had the ability to join meshes and retain the levels of each node we could split the mesh up into bits and assign work to team members and then join the meshes up later. I've tried searching for this as a wish but didn't find anything - can't believe this hasn't been requested before?!
cheers...
2 REPLIES 2
Not to take away from the validity of the wish, just offering some options:
The Morph Tool could be an alternative here. It can do most of the things the Mesh Tool can do, plus any of its edge can be hidden, plus its 2D is a true 3D projection.
I also think the Morph Tool is a more robust tool so it can handle such large complex geometries better.
Also, to start experimenting with this, you can simply copy a Mesh, then convert it to a Morph and see how well it handles stuff.
Thanks Laszlo - will give it a go, as usual when these sort of things come up and become a problem there;s a deadline involved, so will put it on my to do list.
thanks
Learn and get certified!
