Wishes
Wishes: Library Part - Doors - Pivot doors
Nader Belal
Mentor
Hi Graphisoft,
I would like to request a new type of doors to be available with the next iteration of ArchiCAD standard library.
A double panel pivot doors.
Thank you
Post moved to the wishes section.
You can edit your original post and add a poll if you want people to vote.
10 REPLIES 10
Nader Belal
Mentor
Thank you Barry
Minh Nguyen
Thank you very much for sharing the wish!
May I ask for some example pictures of what it looks like? I just want to make sure that I got the right type of doors to enter it into our Wish list database
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
Nader Belal
Mentor
@mnguyen
This is a snapshot from the PDF I was sent by the client, sorry that I can't show more.
PS: The dotted lines are those of the opening lines of the doors' panels
Nader Belal
Mentor
@mnguyen
Another thing I would like to add, ArchiCAD International library should include a frameless doors.
Thank to shoenogome blog article (which I don't have in hand right now), there is a special configuration for doors in the US ArchiCAD Standard Library that permits the users to have frameless doors.
Minh Nguyen
Thank you very much for the clarification!
I enter the 2 wishes as DEF-4827 and DEF-4828 respectively. Hopefully, we will have these 2 types of doors in the near future!
Have a great day!
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
Nader Belal
Mentor
Thank you mnguyen
I would add to the wish the option for these (often glass but can be framed) pivot doors to swing in both directions (should be a parameter - one way or 2 way swing).
One of the forum moderators
Nader Belal
Mentor
@Karl Ottenstein
Door Panels can be framed or not, doors can swing one or two ways .., agreed
