Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
Wishlist | Project Info fields to have data types similar to Properties
Josh Verran
In the Project Info you have the ability to create new fields, however, you have one option for the data type of the field and it's effectively a string.
It would be good if you could choose what sort of data type it was, eg String, Integer, Option Set.
Under the Site Details of the Project Info we have a field which is titled Liquefaction, the options are "Undetermined, Unlikely, Possible, High, Medium, Low, Very Low".
Ideally this would be an "option set" dropdown list that staff could choose from but at the moment they manually delete text to suit.
GRAPHISOFT CERTIFIED ARCHICAD BIM MANAGER
ARCHICAD 18-27 | BIMcloud Basic | CI Tools | Grasshopper - Rhino | CloudCompare | Bluebeam
LinkedIn | www.creativespace.co.nz | Tauranga, New Zealand
Windows 10 Pro | Intel Core i9-9900K @3.60GHZ | 32Gb RAM | 2xSamsung S27F350 1920x1080 60Hz | Nvidia Quadro P2200 (5Gb)
4 REPLIES 4
Jan Vlach
I can see this being very usefull.
From Archicad 8.5 all the way to the present.
Passionate Autocad hater as well.
Wish to save palets and menus individualy in work enviroments:
https://bit.ly/3pg3Bx7
Eugene
We are looking at doing this through Properties with a separate Autotext classification system (distinct from the default Archicad 22 classification system). If you place a dummy object on the relevant worksheet with an initial label associated to it, any drag-copies of the label will maintain the association allowing you to include any Autotext properties within the label. You could make your Liquefaction selection in the Properties pallet by making it the default value from an option set. Fair enough it's not elegant but it should work for boilerplate notes with the option to extend it for use with typical details.
Josh Verran
Another data type/field would be some kind of robust method for entering contacts like consultants. something similar to how the "client full name" field works.
Imagine you want to include and coordinate the info for the Structural Engineer, the Topographic Surveyor and the Quantity Surveyor, in order to show the Names, phone numbers, Title, email address etc you're going to need 20 plus separate fields.
Something like the below with relevant headings and options mentioned above would be ideal.
But at this point it would be very helpful to be able to import those contacts from external database, for example contact list on ones mac/pc.
