I like the SOE-functions in 3d-Script very much and use them often, because it simplify a lot - otherwise there would be a huge amount of 3D-calculations needed for the cutpoints.
I wish something similar for the 2D-script.
I would like to declare a polypoint fence and all should be just displayd in there - cut out.
On the other hand - the same as polypoint hole.
also - i would like to get some command similar to cutplane (in 2d then cutline, cutarc, cutpoly2D and so on)
Of course - this should function for every 2D-object - also project2-commands from 3D - similar to hatches in the normal 2D-Editor in Archicad.
So - it should be possible to script 2D-hatches with normal 2D-Commands within the 2D-Script
