Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
Would like to get same results as SEO (3D) in 2D
Hmooslechner
I like the SOE-functions in 3d-Script very much and use them often, because it simplify a lot - otherwise there would be a huge amount of 3D-calculations needed for the cutpoints.
I wish something similar for the 2D-script.
I would like to declare a polypoint fence and all should be just displayd in there - cut out.
On the other hand - the same as polypoint hole.
also - i would like to get some command similar to cutplane (in 2d then cutline, cutarc, cutpoly2D and so on)
Of course - this should function for every 2D-object - also project2-commands from 3D - similar to hatches in the normal 2D-Editor in Archicad.
So - it should be possible to script 2D-hatches with normal 2D-Commands within the 2D-Script
4 REPLIES 4
Nader Belal
Mentor
@Hmooslechner
Wasn't the Geometry Macro made for that specifically ??
A good friend of mine have once told me that I´m so brute that I´m capable of creating a GDL script capable of creating GDLs.
Hmooslechner
Geometry-Macro: Much too complex to script.. SOE in 3D is much simpler and can be understood even from persons like me.
Nader Belal
Mentor
@Hmooslechner
Just out of curiosity, have you tried to treat 2D polylines as 3D elements using SEO operations ??
runxel
Legend
Heimo, do you know the BasicGeometry macro?
This should be what you're after.
Lucas Becker | AC 27 on Mac | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text |
«Furthermore, I consider that Carth... yearly releases must be destroyed»
