Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
Zone Area Volume results in cu ft rather than sq ft please.
Gus
The Zone tool now presents the Volume of the Zone in Square Feet, but square feet is obviously not a measurement of volume it is a measurement of area. The Volume Presentation therefore simply wrong in every single instance of Zone Volume Representations. Can this be fixed so that we can use the Volume option on the Zone Display? Thanks.
www.michaelgustavson.com Architect NY WI IL
Madison WI
Archicad21 MEP EcoDesSTAR Win10-64-bit
EliteBook8570W Corei7-3630QM@2.40GHz
QuadroK2000m RAM32 (2)250GBSSDs
4 Monitors Internet:4Up60Down
Gus wrote:
The Zone tool now presents the Volume of the Zone in Square Feet, but square feet is obviously not a measurement of volume.
I'm not able to get the zone tool to report s.f. for volume - not sure where/how you're seeing this?
Also, did you try changing the Calculation volume units to your desired units? See attached.
One of the forum moderators
Gus
hm... I think there must be a glitch then in this file, because all those settings say cubic feet but it still shows up as square feet. Maybe it will change back to normal on the next project. Thanks for trying.
Madison WI
