Excellent suggestion. I plan on enhancing my Favorites in my template and will give this a try.
To answer your question, I often need to differentiate groups within the same floor. For example, you might have an Administration category and two distinct groups to break out: Business Development and Quality Management or the like. I use a numbering system and different fills on the plan to show the distinction.
The second challenge is I often have multiples of these groups on a single floor, so it becomes a bit labor intensive to adjust them so they are graphically distinct when adjacent to each other and having the same color.
Lastly, I need to schedule all these areas with area totals from different floors and having a hierarchy would be helpful. I believe I may be able to work this better with the Property Manager going forward,
Crafting the Favorites as you suggest may reduce or eliminate the time spent on graphics and provide another value in the zone schedule criteria.
“The best thing about the future is that it comes one day at a time.” - Abraham Lincoln
AC27 USA on 16” 2019 MBP (2.4GHz i9 8-Core, 32GB DDR4, AMD Radeon Pro 5500M 8G GDDR5, 500GB SSD, T3s, Trackpad use) running Sonoma OS + extended w/ (2) 32" ASUS ProArt PAU32C (4K) Monitors
