Wishes forum
Zones and Zone stamps visible on multiple stories ("Show on Stories")
Thomas Nymann
Hi.
Could future Zones have the "Show on Stories" setting added - Want to have a single zone throughout a building shaft for instance, but shown on all stories.
(Can this already be done???)
Cheers T.
Ryzen 7 1700X 3,8GHz. - GTX 1080ti 11 GB- 16GB RAM
Acer Predator - i7 9750 2.6 GHz - RTX 2070 Max-Q 8BG - 32 GB RAM
8 REPLIES 8
Don't think you can do it with a zone, but you place some dummy object and add a label to it, to act as a zone stamp.
Ussually we have the opening tool for shafts, though I'm sure you have a valid reason to show zone instead.
www.leloup.nl
ArchiCAD 9-24 NED FULL
Windows 10 Pro
Adobe Design Premium CS5
David Gulbrandsen
This would also be very useful for most of the warehouses I design - that usually contains mezzanines/half-stories containing different functions than the storage areas - which some times are several stories high.
regards
David G
ArchiCad since 8.1
MacBook Pro (16-inch, 2019)
macOS Big Sur 11.6
The strange thing is zones can be set to any height and they will display in sections & 3D to that height.
The problem is that zones just can't be set to display in plan on multiple storeys or even for all relevant storeys.
I have made a mention of this over on the developers forum.
If every one wanting this likes the original post here and makes a request to their local Archicad distributor, then maybe some importance will be placed on it.
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
Hi Barry.
I guess we should give it a like in dev´s forum as well - The more the Marrier 🙂
Cheers.
That is not the developers forum here in this community.
It is a completely different forum altogether.
Versions 6.5 to 25
Ok....  Well let´s just hope that more will "like" the original post then 😉 - Thanks for your input 🙂
It will display in Sections? In 3D, yes, but in Sections?
Are we using the same program? 🙂
Laszlo Nagy, Lead Moderator, Community Admin
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, NVidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC25
Loving Archicad since 1995
@Laszlo Nagy
You are correct, they don't show in sections (yet).
We will have to stay tuned on that one. 😉
Versions 6.5 to 25
