2005-03-24 02:30 PM
2005-03-24 11:11 PM
jim wrote:You can create labels to extract all kinds of information from elements, but it requires a little GDL.
I do want to be able to tag the walls automatically with the name of the wall (the composite wall name). I know I could do this with the ID or text, but I do not consider that as automatic. Having some experience with ADT (cumbersome and time consuming in modeling), it had a good tool however for wall tags.
2005-03-24 11:56 PM
2006-05-09 05:58 PM
2006-05-09 10:23 PM
2006-09-04 02:33 AM
2006-09-04 05:06 AM
jim wrote:AFAIK the only way to do that is to use a special character eg a dot or hyphen after the initial three and use the STRSUB command (see manual)
Thanks Karl,
I will give that a wurl tomorrow. I have similiar composite names where my first 3 characters is the designation for the wall, so I will want to truncate the string of text if possible.
Jim
2006-09-04 12:09 PM
Aussie wrote:jim wrote:AFAIK the only way to do that is to use a special character eg a dot or hyphen after the initial three and use the STRSUB command (see manual)
Thanks Karl,
Jim
2006-09-04 12:56 PM
