3x3 wrote:
Last time I checked there was no an address bar whem searching for a location, will check.
No, when you search there is no address bar (as you would see in Windows Explorer - not sure about Macs but I assume they have similar).
You don't need it when searching as you are simply looking for your location to save any way.
Just click to find the path.
If you want to type you can do so in the file path area.
I assumed by 'address bar' you meant the file path area where you can type what you need or search.
