I proposed this very idea to the development team in 2000!... I called it PROPERTY TEMPLATES. Here each individual could create a Template (much like the PARAMETERS of a normal GDL OBJECT)... The FILL INS would then be done AFTER it gets ATTACHED (the same way property objects are attached now; via criteria or individually)... Then you would be able to attach to WALLS and ROOFs as well as other OBJECTS.
Envision, if you will, a Property Template that is for DOOR SCHEDULE (for example). Here this template would have ID, LOCATION, W , H, etc..... All the parameters that can be DERIVED from the object itself would be (In the property template you would make W = A and H = B for example)... Then the other information (that is not really pertinent to the GRAPHIC description of the object) like U-Factors, Hardware Group, Manu, Model, ICBO report, etc., would simply be filled in this property template. It would bring up a dialog of its own or NOW fill inside the INFO BOX for everyday use.
I'd like to hear other comments on this..
Richard wrote:
My big complaint about property objects is that you can't have variable parameters when you attach a property object, like a "real" GDL object does. It would be SO much more useful if you could attach a single "paint color" object, say, to all walls, and then be able to edit the color parameter for each wall, rather than coming up with a different property object for each different color.
At least this is my current (perhaps naive and incorrect) understanding of property objects. That the property object/calculation process is so difficult to comprehend in the first place, bugs me, too!
Duane
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
