This is an autotext issue.
3 ways to approach this:
1.
Edit > Search and Replace Text
This will allow you to search all text fields in your views and replace text.
2.
File > Info > Project Info
Create custom text fields here that you can reference as autotext in all text tools.
Negative side of this: you can't easily move this from one project to the next.
3.
Create 2d objects with text and place those as labels on views. Use the line tools to create the label leader. Edit the object and save it and all instances will update.
www.leloup.nlArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
