HI,
the architect uses the generative forms to create a movement effect on the facade, Cinema 4d has an ingenious solution without using a node, the solution based on a hierarchy "parent, child"
the MOGRAPH module in an ARCHITECTURAL is the solution,for movement graphics
in my Suggestion MOGRAPH could manipulate "move, scaling, rotation" and duplicate an object in ARCHICAD adapted to cinema 4d, the adaptation this process in add a"TAG " to the object in the management of object of cinema of 4d, at this moment the object is created in the library of Archicad it is lockable and manipulable of then cinema 4d, one uses the generator "cloner and its effectors "with the adapted object ARCHICAD quantify the number of objects duplicated and manipulated by Cinema 4d in ARCHICAD
AMD Ryzen 5950x
AMD RX 6750xt
AC27
