Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
complex profile_trace options
soldaotop
While drawing a complex profile it would be quite useful to have a possibility to trace a section (or plan view)
4 REPLIES 4
Rajesh Patil
You can simply copy paste any object from plan section or elevation in complex profile draw window, which later can be used as per your wish. I think this will help you to get your required end results bit faster.
Rajesh Patil
AC 09-27 | INT | WIN11 64
Dell Inspiron 7591, Core i9, 9880H 2.30GHz, 16.0GB, NVidia GeForce GTX1650, 4.0GB, SSD Internal 500GB, Dell SSD External 250GB
This has been wished multiple times in the last decade or so:
https://community.graphisoft.com/t5/Wishes-forum/Trace-Reference-available-in-Complex-Profile-Window...
https://community.graphisoft.com/t5/Wishes-forum/Trace-reference-to-complex-profiles/m-p/269947#M169...
https://community.graphisoft.com/t5/Wishes-forum/Trace-and-Reference-to-be-available-in-the-Profile-...
Vasileios S_
Never thought of that, but that's a good idea! I've always copy-pasted things in profile manager and deleted those afterwards.
You cannot build a line.
Jan Vlach
Cannot agree more, it is an essential wish.
Also. if one selects an existing profile or element to turn into a complex profile in a view that cuts the element perpendicularly (i.e. wall in section or column in plan) then default behaviour should be to open profile manager with that view as a trace.
This wish is really long overdue.
From Archicad 8.5 all the way to the present.
Passionate Autocad hater as well.
Wish to save palets and menus individualy in work enviroments:
https://bit.ly/3pg3Bx7
