The magic wand tool is what you meam.
Yes you can create your mesh and contours with the magic wand tool.
But unfortunately you can just delete a node on a mesh.
Like any polygon element you need to drag a node onto its neighbouring node to delete it.
You can cheat a bit though if you need to delete a lot of nodes.
Select the mesh and then left click on an edge so you see the pet palette.
Choose the "Subtract from polygon" option and draw around all the nodes you want to delete.
Remember you can use rectangular or irregular polygon drawing geometry to get exactly the nodes you need.
This will cut a big hole in your mesh.
If you want to make this area flat you can select one of those hole nodes and use the pet palette to set the height - tick the "Apply to all button" and all the nodes around the hole will be the same hieght.
Now with the mesh still selected left click on an edge and choose the "Add to polygon" option and magic wnad on the perimeter of the hole.
If you set the heights of the hole perimeter nodes you will have a flat fill in the middle.
If you didn't the mesh will retriangulate based on the remaining nodes.
Either way the ones you wanted to delete will be gone.
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
