2003-11-12 03:41 AM
2003-11-12 04:54 PM
Aussie wrote:They can, if you keep your precision at the required superscript.
I wish dimension superscripts could be applied to the measured dimension rather than just the custom dimension. (so if the dimesion is modified then the dimension updates and keeps the superscript)
2003-11-12 10:56 PM
2003-11-13 12:58 AM
2003-11-13 01:22 AM
2003-11-13 07:35 AM
Djordje wrote:I think what John meant was the addition of the unit, like 'mm' or 'm' at the end of the dimension.Aussie wrote:They can, if you keep your precision at the required superscript.
Or did I compeltely misunderstand?
2003-11-13 08:18 AM
2003-11-13 08:36 AM
2003-11-13 04:09 PM
2003-11-13 05:15 PM
Aussie wrote:But it is related to the associative dimension, if you set it to be so in the dimension preferences. You do this by either selecting the extra accuracy option or by the fractions in small type option. And yes the 2 in the square meter bit is superscripted, but try to edit it and it won't let you unless you switch to custom text. I do completely agree that we should have the ability to add custom text to all associative dimensions, not just level dimensions. I'm just trying to clear up how they do work now.
the superscript is a separate text entry and as such is not related to the associative dimension. (get the area of a fill, select it, and open its text properties. You will see that the sq metre bit is superscript)- so it works there so why not on normal dimensions.
