Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
dimension superscript
Aussie John
I wish dimension superscripts could be applied to the measured dimension rather than just the custom dimension. (so if the dimesion is modified then the dimension updates and keeps the superscript)
Cheers John
[/size]
12 REPLIES 12
Djordje
Ace
Aussie wrote:
I do completely agree that we should have the ability to add custom text to all associative dimensions, not just level dimensions. I'm just trying to clear up how they do work now.
Workaround: define secondary dimension. it is plain text, and you can do with it what you want.
LOOOTS of manual work, I know ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Aussie John
Im wary of using custom text since a change of dimension will not update the custom.
It would be good it Archicad showed a suspect dimension like this in a different colour.
Cheers John
[/size]
You can change it yourself. I know it's not automatic, but it's not a whole lot more work considering you'll already be changing the settings of that dimension text.
