Wishes
display order as a graphic override option
Ability to set certain layers to appear behind or in front in graphic override options. So if I have an underlay layer set, it will be behind everything without having to set display order manually.
Erwin Edel
As a workaround for now, you could make a layer combo showing only the one layer, save a view with that layer combo and stack this view on top of your 'normal' view on the layout. Giving you the option to bring that to front.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
That is what I do now.
