I've seen this topic for AC10 but I couldn't find the answer in the thread.
My first problem is exporting the Layout Book in to one DWG file. I.e. layouts should be shown as Paper space in Autocad, drawings (Stories) as displaced drawings in Model space in Autocad. Wouldn't it be great? I suspect it is hard to do, to interlink the paper and model views in autocad DWG.
Second problem is, if I export DWG by publishing the layout (scale 1:50), the linetypes are scaled by approx. 2 times in DWG drawing, the LTSCALE in the Translation setup has no effect on this. If I do a saveas in the story the lines are depicted correctly.
What am I missing here...thx
