2021-05-27 04:41 AM
2021-06-14 02:28 PM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2022-02-24 04:13 PM
Just an update, this still happens to us regularly, causing problems. It's simply impossible to remember to check the file path every time we save a file with a new date, especially for people of a certain age like me 😐. I guess if it's at the OS level there is nothing Graphisoft can do, but I'm still trying to solve this.
2022-02-25 10:17 AM
Hmm smoke & mirrors me thinks. AC can find and save files all day long at all sorts of places to suit its own ends, yet it can't prompt the Save dialog to open at a relevant location other than the last OS stored location? Same thing with Publisher, AC should be able to save relative to the current file location.
2022-09-05 10:32 AM
Where can we vote for this? It is not fixed in AC25.
Archicad is the only software I know that wants to SaveAs a file into a location where LAST file was saved. More often than not, that one is the previous project, if you work on different projects same time. Should be currently open project folder, though. Try this function in Sketchup, for example. Or MS Word. It also concerns the instances, when I
- SaveAs skp
- SaveAs jpg
etc.
What is relevant is, where CURRENT file was saved to, not the LAST one.
---MSWindows, AC25
2022-09-05 10:36 AM
This post was originally created in the old Archicad-talk forum where we could create and vote on polls.
Unfortunately we can't do that in this new forum.
But what you can do is 'Like' the original post and that will count as a vote.
2022-09-05 02:16 PM
Another Pet Peeve is that AC locks to the last type of file you saved to. So if you did a "Save As…" Template all subsequent "Save as" files will save as TPA and this is stupid on soooo many ways.
But at least it is an old bug not an "improvement" in AC26.
2022-09-05 06:31 PM
I agree as well on the save file type default-it should be .PLN. I update our template a few times a month, and as soon as I overwrite the template, I save the file as a .PLN, because I know that will simplify the next "save as" --but of course it has taken me 10 years to develop this unnecessary habit.
2022-09-05 09:45 PM
Worse issue is when you save-as to DWG (or PDF, Renderings) and then do another save-as for a new PLN version and forget to check.
After the second one every single CMD+S will rewrite your previous project version and/or when you close AC you will either lose all your work if you select "cancel" when AC ask for a save or you will permanently overwrite the previous version.
2022-12-28 08:31 PM
This CONTINUES to be a total pain for us. I have an intern working remotely and she "lost" a file just this week (forgot to warn her). Graphisoft PLEASE FIX! Just now I was working in openoffice writer (open source office software) and when I did a "save as" it defaulted to the location where I opened the file. This has to be super easy to fix.
2023-02-24 02:34 PM
Is there a solution already? Also for the standard save as .PLN and not .DWG?
