2004-04-13 09:24 AM
2004-04-13 11:07 AM
2004-04-14 08:57 PM
Mark wrote:The pet pallette can be used on all linear elements for chamfering and filleting - see Alex Schamenek's tip at
Just like a wall can we fillet, chamfer, and intersect a beam. Furthermore should this tool really be listed under 'line extras'? when currently used for lines and walls and hopefully soon beams.
2004-04-15 12:35 AM
Djordje wrote:This is true but you still need to intersect the beams first.Mark wrote:The pet pallette can be used on all linear elements for chamfering and filleting - see Alex Schamenek's tip at
Just like a wall can we fillet, chamfer, and intersect a beam. Furthermore should this tool really be listed under 'line extras'? when currently used for lines and walls and hopefully soon beams.http://archicad-talk.graphisoft.com/viewtopic.php?p=7810#7810
2004-04-19 04:46 PM
2004-04-19 08:15 PM
TRIBU wrote:Yep, instead of MagicWanding it ... although that does quite a good job. If I need a smooth curved beam, I do it with a slab.
Maybe it is good to have smooth curved beams, too.
