2009-02-09 12:26 PM
2009-02-09 02:09 PM
2009-02-09 02:11 PM
2009-02-09 08:07 PM
2009-02-10 05:46 AM
B wrote:Could you post a screenshot of this issue?
I don't know if other people have run into the same problem, but when we set v12 doors to simple 2d plan symbol it displays a door swing & opening based on the rough opening rather than the door opening. the drafting standards that we conventionaly use here is that the opening show for a door on 1/8" plans is the same as the door opening not the rough opening. ealier versions of ArchiCAD doors (v11) work properly.
Also it seams there are still several problems with trim options that make the doors not useable. We have had to resort to using v11 doors and windows to get workable library pars.
2009-02-12 02:44 PM
2009-02-12 04:38 PM
