2004-02-14 12:00 AM
2004-02-14 12:38 AM
2004-02-14 06:07 AM
Aussie wrote:This would be great, we would just need a simple way to disassociate the elements when as needed. My other concern is what happens to performance as we start adding more inter-element relationships to maintain. As I recall this was a serious problem with early versions of Revit and may still be an issue with the later versions.
After apply an item via gravity to a slab/roof/terrain, shouldn't that item move with the object when the base element is raise or lowered.
Also why do we have to differentiate between the 3 type of elements.I assume this is because they can be laying over one another in plan when using a model oriented layer combination. I for one like being able to be explicit about which type of element I want to drop something on.
Let archicad automatically select the element
and why while we are at it how about a ballon effect of attaching to the underside of an element.This is an excellent idea! I'm surprised it never occurred to me. It would be a great way to install lights, fans, crown mouldings and all sorts of things.
2004-02-14 12:54 PM
Matthew wrote:And level dimensions for ceilings.
2004-02-15 12:12 AM
James wrote:It is possible now but need a library part that takes into consideration the thickness of the element of the ceiling.
2005-08-23 07:39 PM
Aussie wrote:And an element placed with gravity on should stay 'on-face' when it is dragged across a mesh or roof surface. I thought about posting a fresh wish for it, then I found this one.
