Wishes
inherit parameter attributes in object/door/window settings
__archiben
who finds it annoying that object/door/window parameters revert to that objects default when you change from one to another?
with the introduction of subtypes and a more structured parameter approach from graphisoft, i wish that we had an option in door/window/object settings that enabled the object to inherit any parameters originally defined when browsing/changing objects.
for example, changing door types . . . you may set all of the parameters up for a specific door - frame width, rebate, etc.., etc.. and at a later date need to change that door. any common parameters are lost back to the new doors default values. . .
~/archiben
b e n f r o s t
4 REPLIES 4
Everyone. Except people who are dead, or are otherwise not using AC.
I'm compiling a list of time sink wishes: simple stuff that should already work, that we have to manually compensate for every time. This is on it. Essential.
James Murray
Archicad 25 • Rill Architects • macOS • OnLand.info
Dave Jochum
Drives me nuts. There have been many discussions on this forum and the old email list. Unfortunately, at this time there is simply not a good door/window solution for AC that I know of.
Dave Jochum
J o c h u m A R C H I T E C T S http://www.jochumarchitects.com
MBP 16" (M1 Max) 64 GB•OS 13.5.2•AC 27 Silicon (latest build)
TomWaltz
While I would like to have some way of maintaining parameters between objects, it needs to be an option, not a mandate.
There are times where you *want* the default options, or want to revert to them from what you have set.
Tom Waltz
__archiben
me, wrote:
i wish that we had an OPTION in door/window/object settings . . .
quite!
~/archiben
b e n f r o s t
