Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
layers list - switchable
As there is no dockable (permanent) layers palete, I want to switch layers on/off using layer selector on Info Box (click "eye" icon...) I know, autocad again.
But it makes sense to me: I see an unwanted object. Want to turn it's layer off. Don't know what layer it's on. Select it, go to layer button, on the roll down list poke the eye
jonaszluszpinski wrote:
But it makes sense to me: I see an unwanted object. Want to turn it's layer off. Don't know what layer it's on. Select it, ...
Just turn on the 'Quick Layers' palette (ALT+Q is the default shortcut).
Select the object and turn off its layer.
Also allows you to do other things - turn off all other layers and invert current layers.
The same can be done with locking/unlocking layers.
… and the best thing is you can then "Undo" (on the Quick Layers palette, not CMD-Z) to go back to your previous layer state(s)
David Maudlin
With the element selected, right-click, in the context menu go to Layers > Hide Layer.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
