Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
line weight shows differently in complex profile and on the floor plans
soldaotop
Hi
This problem that I'm having has been showing up for some time on various projects and I can't figure out the reason why it is happening nor what causes it.
In my complex profile section when I set line weights to certain fills everything look fine, and it is like this:
(section complex profile )
But when i go to a floor plan the things don't show up as set in the complex profile:
(floor plan)
as it is visible,  the left line of a reinforced concrete element is a light line while it should have been thick.
Do you have any idea why this is happening and how to fix it?
Thanks
4 REPLIES 4
Miha_M
I noticed the same thing in a composite profiled wall yesterday but couldn't find any solution yet (v25). Floor plan here:
Profile manager:
| Archicad 4.55 - 27
yes, v25 here as well. And just to add that everything looks fine in sections, so the problem appears only on the floor plans
I don't know if any of these ideas will help.
Does adjusting the Floor Plan Cut Plane height make any difference?
Turn on/off the bold cut lines.
Turn on/off true line weight.
In the profile manager, bring the concrete fill to the front.
The display of complex profile walls in plan can be troublesome, which is why I made this wish to be able to select a symbolic cutting plane for representation in plan.
https://community.graphisoft.com/t5/Wishes-forum/Symbolic-view-for-complex-profile-walls/m-p/256277
So far only one like. 😥
Yes that's a great idea! but so far as I see still just a wish 😕
And unfortunately none of your proposal didn't fix the problem ...
