‎2022-11-10 03:04 PM
Hi
This problem that I'm having has been showing up for some time on various projects and I can't figure out the reason why it is happening nor what causes it.
In my complex profile section when I set line weights to certain fills everything look fine, and it is like this:
(section complex profile )
But when i go to a floor plan the things don't show up as set in the complex profile:
(floor plan)
as it is visible, the left line of a reinforced concrete element is a light line while it should have been thick.
Do you have any idea why this is happening and how to fix it?
Thanks
‎2022-11-10 06:56 PM - edited ‎2022-11-11 08:18 AM
I noticed the same thing in a composite profiled wall yesterday but couldn't find any solution yet (v25). Floor plan here:
Profile manager:
| Archicad 4.55 - 27
‎2022-11-10 08:14 PM
yes, v25 here as well. And just to add that everything looks fine in sections, so the problem appears only on the floor plans
‎2022-11-11 01:49 AM
I don't know if any of these ideas will help.
Does adjusting the Floor Plan Cut Plane height make any difference?
Turn on/off the bold cut lines.
Turn on/off true line weight.
In the profile manager, bring the concrete fill to the front.
The display of complex profile walls in plan can be troublesome, which is why I made this wish to be able to select a symbolic cutting plane for representation in plan.
https://community.graphisoft.com/t5/Wishes-forum/Symbolic-view-for-complex-profile-walls/m-p/256277
So far only one like. 😥
‎2022-11-11 04:19 PM
Yes that's a great idea! but so far as I see still just a wish 😕
And unfortunately none of your proposal didn't fix the problem ...
