Or you could use the Attribute Manager to bring in the new composite (and others at the same time) so they are an exact match and you don't have to remember their settings.
Keep your template up to date with the Attribute Manager if you ever create new attributes in your jobs.
That way when you start a new job from your template everything you have used before is at hand and you only have to create something if it is really new.
