Wishes forum
<Revision ID> as a parameter
Gerald D Lock
I'd like to see a Layout Book parameter added in the next release called
"Revision ID"
As we all know, drawings get issued with a sequential revision ID (numbers or letters, depending on your office protocols)
This ID is unique to the Layout, as some drawings may not be changed in a particular revision issue.
This parameter could then be used for the following functions:
- Autotext (for adding to titleblock masters)
- Layout titles (so that it's clear what revision the layout is, from the Layout Book tree, as well as when viewing the layout itself)
- Filename (ID would be appended to filename when publishing from Layout Book)
- Interactive Schedule (added as a column to the layout Index schedule, this would allow this information to be shown on the drawing set cover page)
I hope you all agree - this is an ESSENTIAL feature that has been missing for a long time and needs adding ASAP
Thanks for reading & giving your consideration & support to this wish!
ArchiCAD 24 (build 5004)
MacBook Pro (16-inch, 2021) Apple M1 Pro 32GB RAM | MacOS 12.0.1
Melbourne, Australia
5 REPLIES 5
Dear GS - this simple request has been asked for years - for a few releases now.
A minor bit of coding on your part would go along way to assisting in documentation process - it is still unbelievable that there is no way of managing Revisions in ArchiCAD! (v17 and counting!)
Definitely worth repeating
"Revision ID"
I'm guessing you might like the new Revision Management in 18.
http://www.graphisoft.com/archicad/archicad-18/overview/
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
Eduardo Rolon
"might"?
eduardo rolón AIA NCARB
Another of the forum moderators.
Macbook Pro M1 Max 64GB ram
OS X 10.XX latest
AC25 US/INT -> AC08
Puerto Rico, BVI, Miami
Vectorworks 2022
Rob
that's what I call a topic with happy ending...
::rk
Labels
