I'd like to see a Layout Book parameter added in the next release called
"Revision ID"
As we all know, drawings get issued with a sequential revision ID (numbers or letters, depending on your office protocols)
This ID is unique to the Layout, as some drawings may not be changed in a particular revision issue.
This parameter could then be used for the following functions:
- Autotext (for adding to titleblock masters)
- Layout titles (so that it's clear what revision the layout is, from the Layout Book tree, as well as when viewing the layout itself)
- Filename (ID would be appended to filename when publishing from Layout Book)
- Interactive Schedule (added as a column to the layout Index schedule, this would allow this information to be shown on the drawing set cover page)
I hope you all agree - this is an ESSENTIAL feature that has been missing for a long time and needs adding ASAP
Thanks for reading & giving your consideration & support to this wish!
ArchiCAD 24 (build 5004)
MacBook Pro (16-inch, 2021) Apple M1 Pro 32GB RAM | MacOS 12.0.1
Melbourne, Australia
