2013-07-02 11:07 PM
2013-07-03 12:11 AM
2013-07-03 04:48 AM
s2art wrote:Stuart,
It would be handy if you could adjust them floor by floor as well.
2013-07-03 05:37 AM
Barry wrote:Almost. It means a bit of phaffing around with layers and visibility per storey, but since when have workarounds not required a bit of extra effort? I realise having the marker heads displaying differently on each storey would not necessarily be easy. Cadimage have something similar in their roof accessory, whereby you can display certain elements on certain storeys - i.e. whole accessory on roof plan, downpipes only on storey below (and the downpipe offsets back to wall line too), and outline only for stories above.s2art wrote:Stuart,
Place a new section on your other storey but change the marker type to "Linked Marker" and link it to your original section view.
Make sure both section lines only show in the storey you want them to show in.\
Now you can adjust the width (or even the location) of each section line independently but they will both show the same section (the source section).
Is this what you are after?
2013-07-03 03:26 PM
another Moderator
2013-07-03 10:35 PM
ejrolon wrote:Perfect.
Or you can pay Jeroen
http://www.masterscript.nl/labels-and-markers/32-section-elevation-marker-offset.html
