Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
mult-plane roof stretch
Dave Brach
I would like to be able to stretch the gable end of a multi-plane roof in 3d view
Dave Brach/architect
AC26 MBP OS Ventura
AMD Radeon Pro 5300M 4 GB
Intel UHD Graphics 630 1536 MB
Hello Dave Brach,
Do you want to modify your walls, roofs or both ?
Is it a operation between a current view and a projected view ?
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 11.6 Big Sur - MacBook Pro 2017 - 16Go RAM
Dave Brach
I don't need to modify walls. For instance if I would like to see how a 50 cm roof overhang looks instead of a 100cm overhang. I would like to do this in 3d view instead of going to 2d view.
AC26 MBP OS Ventura
Hello Dave,
In 3D you have to pull your roof by a segment and select this option in the context menu :
Then input the distance...
It's the same operation than in 2D but in both you have to verify your georeferencing.
If you do not check the georeferencing, the shadow projection will be wrong.
Can you illustrate your problem if I did not give you the answer you wish ?
Christophe - FRANCE
