That is when you use a linked section marker - that is linked to the original section.
Now you can show each section marker in the storey applicable and can adjust the lengths separately.
But because they are linked they will open the original section (elevation).
Just make sure the original section is set to display the correct height for all storeys even though it only displays on one storey.
