Wishes
pallet docking
giza
why can't we have possibility to dock all other pallets except standard AC (info box, navigator, navigator preview,toolbox, coordinate box etc) in AC workspace window, if i am using a 20'' monitor i want my workspace to be well organised with nothing floating around so i vote for docking Element Information, Favorites, Quick layers etc, and all other non graphisoft addons like archiforma or similar
thanks
Gezim Radoniqi | Architect | BIM Manager @ 4MGroup
ArchiCAD user since version 6
AMD Ryzen 3950X CPU, 64 GB RAM, NVidia RTX 3060 12GB
14 REPLIES 14
i'm a new user from vectorworks to archicad, there are to thing about the interface that i don't know why archicad does not have, one is the automatic pan at the time you're in a command and second this, all the pallets need to contract and expand.
A good idea to do something to improve toolbars. When I open a toolbar and it floates around in my drawing and I try to lay it into the toolbars it makes a new line and use up my drawing window. It irritating. I think Microsoft office 2007 user inteface is much better.
Yes - Agreed - Critical to stop wasting time with the traveling pet pallets.
Should be designed as a stationary pallet that can be docked with other pallets.
WASTE OF TIME moving this pallet out of the visual screen when trying to work.
Get Rid of Pet Pallets.
__archiben
whilst i agree that some of the palette control could do with a bit of work, the auto-pan thing has never really bothered me: you know that you can still zoom and pan with the scroll wheel whilst you're in a command, right?
~/archiben
b e n f r o s t
__archiben
are you crazy?! what's needed is a more contextually aware command system at your mouse point! (maybe along HUD lines...?) not getting rid entirely!
that the polygon and 3D stretching commands are available right next to you when you need them rather than having to go find them is A Good Thing.
two things for you to try though: first off, in your Work Environment>User Preference Schemes>Dialog Boxes and Palettes... you can control the distance from your cursor that the pet palette appears and moves. and if that still doesn't float your boat you CAN have it appear in a set place all the time. just set the movement to 'Jump to Preferred Position' and the next time it appears drag it to where you want it. it will remember that from then on.
(it's useful to know exactly what you are talking about before you start complaining about something too! )
~/archiben
b e n f r o s t
