Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
[poll] Text body resizes as scale changes
tsturm
I have found it very difficult to put room names in rooms at one scale only to find the text gets all messed up when the scale changes.
For example drawings done at 1/16" and then used at 1/2" for another reason. The text used for both scales gets jumbled or wrapped oddly depending on the starting scale the text was ended from.
So the request is to resize the text box as the scale changes so the boxes always have the same relationship to the text they contain.
Terrence Sturm, Architect
_______________
MBP OSX 10.15.4 Quad Core Intel i7 2.2hz
AC 17 build 5019
AC 22 build 7000
AC 23 build
AC 24 build 5000
1 REPLY 1
TomWaltz
easy way around that one is not to use text boxes. Double-click on your starting point and the text resizes exactly where you put in your line breaks.
Tom Waltz
