2010-03-03 12:00 PM
2010-03-03 05:11 PM
2010-03-04 03:33 AM
2010-03-04 08:10 AM
2010-03-04 12:00 PM
Matthew wrote:So true Matthew. Sounds like those ancient oriental proverbs. I'll frame it and stick it on my office wall.
There are lots of things that behave as a unit but consist of numerous discrete components.
Matthew wrote:I guess it could be achieved with a dynamic array of called objects with x,y,z,rotx,roty,rotz individual parameters (all currently feasible)... The "only" (sorry Zsolt ) thing left would be make those called objects available for listing/scheduling. Not perfect, but could be a start toward the "Assemblies Nirvana".
What I envision is a single instance of a wall opening with multiple macros/parts associated such that each can be mixed, matched and independently adjusted (within reason) and scheduled as assembled units or as component parts.
2021-09-05 12:16 PM
I came across this thread when I thought how good it would be to be able to place a table object that would automatically also place separated chair objects.
I believe this is what is proposed here and I find it a very needed function in gdl.
It should be a PLACE command or similar, that would place a separate object, passing position, scaling and other configuration parameters at the moment it was place. It should also have parameters for grouping (on/off).
This way we could place a table with 6 chairs, and after placement, edit, move, delete, and schedule each of this objects separately. What a powerful command it would be.
2022-04-11 05:02 AM
I've came across this thread, when I wanted to do the following:
1. I created a custom subtype for light fixtures, to add or remove parameters globally to those elements that are using the subtype. At this level I'm giving "not defined" default values for each. (e.g. for the short description, VSG, light colour temperature, etc.)
2. I'm setting the actual parameter values in the actual objects in the parameter script, which works fine.
3. I wanted to list these values in a schedule, and although I'm using the "same" parameters from the subtype in many objects, I need to select the parameters from each actual object to display it's values properly, which is baffling - this means I cannot display more than one type in a schedule...
Is there some plans to improve this? If not, are there plans to introduce "type parameters" to the Archicad property manager? Right now the separation of GDL properties and the property manager is infuriating, and confusing a lot of new users...
2022-04-11 05:43 AM
I am not quite sure I am following the problem here.
I have some windows for which I have created a 'sub-type' to automatically add the required parameters to them.
All windows that have this sub-type, have these parameters.
If I schedule these windows (all different objects) and I add 'Library part parameter' to my schedule, I only have to find that parameter from one of the window objects.
All other windows that have that parameter (i.e. using the same sub-type), will also schedule that parameter.
I don't have to find that parameter in each window to add it to my field list.
