Wishes
"Clean Wall & Beam Intersections" available when drawing
ricardord
It used to be possible to "Clean Wall & Beam Intersections" when drawing a wall.
Now, when I click the first point the "Clean Wall & Beam Intersections" option is no longer available (it's greyed-out).
Is it not possible to bring this option back?
Thanks,
Ricardo
ArchiCAD 22 Solo – MacOS 10.13.6 > iMac 27 i5 3.2GHz . 16GB RAM . 1GB VRAM – MacOS 10.14.6 > MacBook Pro i7 2.6GHz . 8GB RAM . 1GB VRAM
2 REPLIES 2
It makes no difference to how the walls actually connect.
All it does is show the connection on or not in plan view.
There is no need to change it while drawing a wall.
Generally you will want to leave it on all the time so the connections display correctly.
But if you want to see the true wall extents with no auto-connections, then you can turn it off.
But I would say you would rarely want to do that.
I think you should try to check if you groups are enable or if your selection deals with a element about a module
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 11.6 Big Sur - MacBook Pro 2017 - 16Go RAM
"Quality is never an accident ; it's always the result of an intelligent effort" John Ruskin
Learn and get certified!
