Wishes forum
"Link drawing to" in Layouts
Mark Davis
When using the "Link drawing to" command once a drawing on a layout is selected, it brings up all the views open in the tree.  It means you have to scroll & close through many views to find the one you want to change the drawing to.  Instead it would be great if it opened to the view tree with everything closed.  That way you can quickly go to the view via opening the folders & select the new view.
8 REPLIES 8
Lee Hankins
Mentor
Absolutely agree. And have the search functionality the same in the Navigator. I think I have suggested this too.
Lee Hankins
ArchiCAD 4.5 - Archicad 26UKI Apple Silicon 4032
macOS Ventura (13.2)
DGSketcher
Champion
I'm hoping the search option is added in AC27, it was an obvious omission from AC26 which was attributed to a shortage of development time.
The open list can be shut down by ALT / Opt - Clicking the top folder. The good news on the open list is the current linked file is usually highlighted so it is easier to find by quickly scrolling and looking for the highlight.
Apple iMac macOS Ventura / AC26UKI (most recent builds)
Thanks for that.  Do you know what keys for a mac?
Please also add my suggestion to color code folders and ability to hide unused views on clones folders
Just move your mouse to the top folder and hovver over the expand / collapse arrow, then press and hold the [Option] key (bottom left of keyboard) while you left click your mouse. If you click a second time it will expand all folders. You can also do this on subfolders., and it also works in Navigator.
You don't have a signature, so I don't know which version of AC you are running, but it definitely works as far back as AC24.
I don't have a problem with colour coding, but GS seem colour averse, so who knows.
We're going off topic here, but personally on the cloning front, my thoughts are that the Project Map needs subfolders to enable grouping of sections e.g. by anticipated view scale or content etc which can then be cloned so we don't have to waste time hiding all the irrelevant Views or as present dragging views individually, which takes longer to Manage. This is one of those easy changes that would bring significant productivity improvements...
It has been discussed previously... https://community.graphisoft.com/t5/Design-forum/Folders-and-Searchbar-for-Worksheets/m-p/264571
Thanks.  I'm on AC26.  The folders are greyed out & it didn't work for me unfortunately.
You are right! Why add color and much needed functionality if it would interfere with aesthetics!? 😂. Architects
Joke aside, a more automated way of naming views (something like the id manager, so you can automatically add and manage prefixes to different type of sections like kitchen sections, window sections, etc, which in turn could generate a subset of sections), coupled with your suggestion of cloning specific views within folders would be quite powerful.
