Wishes
"Replace" function in "Attribute Manager"
"Replace" function next to "Delete and Replace with...".
"Replace" function should work very similar as "Delete and Replace with..." just not deleting Attribute but only replacing it to other Attribute. This is useful when you what to change many elements at once, for example surfaces. . .
GRAPHISOFT BIM Manager Training Week attendee
ArchiCAD v9 - v26 INT / NOR (5002)
cpu i5-12600K @ 5.0Ghz, ram 32GB, gpu 1060 GTX
ssd NVMe, Windows 11
ArchiCAD Discord channel: https://discord.gg/QdWxSJ33
5 REPLIES 5
So you want to replace one attribute completely with another (effectively deleting it) but you want to keep the original attribute?
The replaced attribute will not be in use any more but will be available to use it again straight away.
Saves you having to import it back in from another file?
Is that what you mean?
Exactly. I don't want to make attribute import when I make "Delete and Replace With . . .". Just replace with other and keep both of them in file.
insideru
Just duplicate the original Attribute, delete and replace with then rename the duplicate to the original value.
ARCHICAD 27 INT
macOS Sonoma
Except that will create the same attribute with a new index number.
Which can be a problem if you copy and paste from another file or link modules.
It is better to import the attribute from another file so it keeps the same attribute number.
Or I guess you can use the new re-numbering or attribute option in 25 to set the duplicate back to the original number.
Minh Nguyen
Hi All,
Thank you very much for sharing this great idea!
I am happy to say we took notice of this wish and I have added it to our Wish List database (please refer to it as IDEA-11850). Hopefully, our Product Management team will adopt this one in the future.
Thank you all once more, and I wish you a great day!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
