It would be nice if one could assign view setting properties to a folder in the view map so when you drag a story, elevation, etc. from the project map to a folder in the view map the story, elevation, etc. would take on the properties of the folder. That way if you are working on a 1/8" construction document set and need to add a plan to the 1/4" marketing folder in the view map you would not have to change your view settings to do so (just to give one example).
