2022-07-28 12:45 PM
Hi
Am I missing something or it's impossible to dimension a radius of a round column with the radial dimension tool?
While with a 2D object such as a circle or an arc it doesn't seem to have any problem, I can't find a way to do that with a column (?)
2022-08-02 05:03 PM
You can do that with the label tool. Out of the box you get the diameter/width parameter but you can make a property to calculate the radius.
