2004-04-09 02:54 AM
2004-04-14 09:11 PM
Dwight wrote:ahem ... I still prefer spline magicwanded into marquee, and then, if needed, SEOs.
Link has already identified the "free line cut" method you ask for - as close as it can be in ArchiCAD:
Dwight wrote:... not to mention the 3D view that should (have to try it properly!) preserve the marquee and the storey visibility
You can also define your visualization area with a complex marquee, selecting only the storey you want to visualize.... and preserving the marquee path by using an outline on a special layer....
