2022-08-05 12:16 PM - last edited on 2022-10-04 11:53 AM by Oleksandra Vakariuk
Problem: Archicad sliding doors have their moving leaf on the outer side, while in many countries the industry standard is having the sliding leaf on the inside of the external sliding doors. I can flip the opening direction but this causes problems when scheduling doors because the frontal view will be mirrored. Current workaround is creating a separate schedule for sliding doors, which is cumbersome and makes schedule difficult to understand by contractors and manufacturers.
Proposed solution: add the option to select inwards or outwards sliding leaf.
Additional problem is that the exterior surface doesn't apply to the side of the outer door leaf, it shows the interior surface, which causes problems during rendering.
(hi, @Csilla Mai!)
2022-08-05 05:46 PM
I agree!!
2022-08-08 10:50 AM - edited 2022-08-08 10:51 AM
Could you use View from Reveal Side instead?
Can you show a screenshot of your material issue?
Ling.
AC22-23 AUS 7000 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win10 | R5 2600 | 16GB | GTX1660 |
2022-08-08 01:17 PM
Thanks for the reply.
View from Reveal Side fixes the front view being flipped, unfortunately if I want to show a floor plan view of the door, it's flipped compared to the front view.
the top row is View from Reveal Side, middle is View from Opening Side. The floor plan view always aligned so opening side is upside. This flips the sliding door. This contradictory information is difficult to read by the manufacturer, leading to questions or in worse cases manufacturing a flipped door, which will be considered to be planning error.
The material issue is shown here:
2022-08-09 06:47 AM
Sounds like an issue that has been around for the past 15+ years. Maybe if we wait another 20 they will have fixed it... As far as I know, they just need it to read two variables for the placed door / window to orient them correctly. WIDO_REVEAL_SIDE and maybe SYMB_MIRRORED.
