2005-10-08 11:45 AM
2005-10-09 05:50 AM
zucoc wrote:Try using wall extras in the meantime ...
sloped walls !
PLEASE!
with doors and windows
2005-10-09 09:53 AM
2005-10-17 12:08 AM
zucoc wrote:you can use the structural steel objects in the library and add some inclination angle . . . or for more solid polygonal columns, use the basic elements - again with inclination angle.
and I would like to ad:
-sloped columns
-sloped beams (not the roof workaround)
2007-09-28 12:08 AM
2007-10-29 09:18 PM
2007-11-12 07:16 PM
genarch wrote:Do you know of a way to give your mesh a uniform thickness for this type of thing?
I often use the mesh tool for this, but you can't use the composite wall types...
2007-11-12 07:23 PM
Evan wrote:I'm not sure what you mean... I start out by drawing the mesh as a rectangle that is as wide as my walls. Then, in the 3D window, I drag each corner vertically to where I want it to go.
2007-11-12 10:34 PM
