Wishes forum
special behaviour fields in schedule
alemanda
I wish an option in the schedule that allow us to have fields which not create a new record ...
I Try to explain it better with an example.
Suppose to have a door schedule and the door type "W01" is located at 1st, 2nd and 4th floor ...
At the moment if you include the "home story" in the list of fields you will have 3 records ... well, I'd like to have one record only where the field "home story" is filled with a list like this: "1st, 2nd, 4th"
In other words I'd like to have "not discriminating" fields
AC 19 and AC21 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores)
32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 25'' 2560x1440
www.almadw.it
3 REPLIES 3
You mean, you would like a schedule to be able to display all values used by a given item?
For example, in Revision History objects (it is a GDL Object, not a Schedule, I know) the simple layout will list 1 revision by row, and in one cell it will list all Changes that belong to that Revision, for example: "Ch-01, Ch-03, Ch-05".
Such a feature would be useful.
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC26
Loving Archicad since 1995
alemanda
Exactly.
Win 10 Pro 64bit
www.almadw.it
LGreen
This would be incredibly useful for door & window schedules. This is currently the largest issue we have with using the schedules for doors & windows.
It could simply be another button next to the order / sum / flag buttons in the scheduled fields. The schedule would ignore that field when determining if two items are the same and then list out the different pieces of data. Easier said than done I'm sure, but it would be very useful.
Lachlan Green | Architect | Drafter
AusBuild
AC23 & 25 | Windows 10 | Intel 11Gen Core i7 | 2.5GHz | 32GB RAM | Nvidia T1200
