Hi Dave,
Thank you very much for sharing your wish!
Please excuse my limited knowledge in localized versions, as I always use INT for my daily work. Is it true that the current window objects in the USA library are lacking option to make tilt-turn/sliding sash? Such opening type is available in INT version and can be combined together, however, I couldn't find out how to do it using USA library.
Let me know if I understand the wish correctly! Thank you very much for your help!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
