Wishes forum
tilt turn windows in USA library
Dave Brach
USA library should have full array of tilt-turn window objects, eg combination units with multiple tilt-turn sashes, tilt-turn/fixed combination, tilt-only units, tilt-slide doors etc. Thanks
Dave Brach/architect
AC26 MBP OS Ventura
AMD Radeon Pro 5300M 4 GB
Intel UHD Graphics 630 1536 MB
Minh Nguyen
Hi Dave,
Thank you very much for sharing your wish!
Please excuse my limited knowledge in localized versions, as I always use INT for my daily work. Is it true that the current window objects in the USA library are lacking option to make tilt-turn/sliding sash? Such opening type is available in INT version and can be combined together, however, I couldn't find out how to do it using USA library.
Let me know if I understand the wish correctly! Thank you very much for your help!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
Dave Brach
yes, as far as I can tell, the USA library has only one window option for tilt-turn. It does not allow "combination" units (fixed + tilt turn in one unit), and id does not a have "tilt-only" (no turn)
AC26 MBP OS Ventura
Minh Nguyen
Hi Dave,
Thank you for your confirmation! I have entered it into our WishList database. Hopefully, our Product Management team will adopt this one in the future!
Have a great day, and stay safe!
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
