2006-06-12 05:22 PM
2006-11-24 07:51 AM
2006-11-24 09:37 AM
2006-11-24 09:42 AM
2006-11-24 03:53 PM
2006-11-24 06:15 PM
2006-11-24 06:21 PM
2006-11-24 07:13 PM
Dwight wrote:Fills could simply acquire the current tool settings as the author suggests. Even if its not what was desired, its a simple fix. Slabs and roofs could be a little more troublesome what with thickness, slope, elevation, material settings, etc... But as long as the function were consistent (using the default tool settings) it would be easy to get comfortable with it.
I voted essential on this since there's been more than once where I was frustrated by the numerous shadow fill bits generated in a complex elevation.
I can see that the command would be simple:
Select fills: UNIFY.
If you diidn't use Find and Select to select only one fill pattern/color, and you had more than one in the selection, the tool would ask which one to apply. That COULD get complicated.
2006-11-28 11:03 AM
2006-11-29 02:19 AM
