Wishes
wall cover fill
soldaotop
When we will finally have the possibility to have a cover fill option for uncut walls ?!?
9 REPLIES 9
Are you talking about Floor Plan representation?
So, for example, there is a slanted Wall and you want cover fill on the projected Portion below the Floor Plan Cut Plane?
soldaotop
Yes I'm talking about Floor Plan representation. The thing is that for the purpose of the presentation I would like to have my walls covered with fill (solid or pattern doesn't matter).
That walls are being of 1m height, so therefore they are not cut. I don't find any option of coloring them, besides drawing an extra fill over the wall which is rather unhandy
Thanks!
That will do for sure.
(Though it would be much easier to have that option regardless graphic overrides, like other elements have that option)
Strawbale23
I would like to be able to do "sections" of plans, using the AC25 section options.
AC26
https://www.zendsign.fr/
Strawbale,
If you have another wish, please start a new thread, let us keep threads nicely organized so one thread is about one wish.
Is there any way to apply the graphic override only for walls that are not cut in floor plan? For example, I have set up an override style with the desired fill type, however there are several walls in the floor plan, some of which are cut and some of which are not.
You can create two GO RULES, one for cut walls & the other for uncut walls.
AC 27 INT 5003/WIN 11
DGSketcher
Legend
I would like to take this wish a bit deeper and suggest that while GO's provide a basic solution, they don't respect the various materials in composite & complex walls.
There needs to be a better way to add cover fills to walls so that they display the relevant exposed skins with a choice of cut, surface or custom fill.
I have just been challenged by this very problem on a sloping site where the complexity of slicing the model to display the different skins & materials was impractical. The solution - convert all affected walls to individual Morphs representing the separate skins. 🙄 At least there is now some consistency of presentation & BIM data retention in my drawing, but this solution has taken w_a_y longer than it needed to. Cover fills to walls is another of those long standing wishes that really should have been resolved by now.
