2007-10-30 01:32 PM
2007-10-30 02:38 PM
2007-10-30 05:39 PM
Peter wrote:Exactly right, Peter. Further, if the main roof and all of the dormer roofs are selected as the operator, then everything will be trimmed as desired with the SEO - and remain live through further editing.
Could you use SEO with upwards extrusion instead of trim-to-roof perhaps? It should do what your trying to do with only a single wall and roof, athough you will get an extra line where the dormer cheeks hit the main wall.
2007-10-31 11:30 AM
Peter wrote:Thanks > I'll look into using SEO as you suggest, though as you point out, the problem is that the exterior walls' (face wall and cheeks) siding won't wrap around the corner of the dormer (or, will they?). My multiple walls and roof solution did do that.
2007-10-31 12:07 PM
